Hi Y'all,
Could anyone help me identify this movement at all please?  I need to try to source a stem/crown for it as it came to me without either.  I suspect some sort of cheapy Chinese (or other) effort?  I mean, it sits in the back of a fake Omega Seamaster so I doubt we're talking high end here :)  However, my mate likes the watch so I'd like to try and get it sorted for him.
Thanks in advance.
Cheap Chinese you said ... cheap Chinese it is.
DG 2813 ... DG meaning Dixmont Guang Zhou ... or nothing as there are certainly multiple manufacturers.
You can find stems on the net but the problem is you could pay $9 for the stem only and $16 for the complete movement.
Depending on where you live some close forum member could send you one (I'll check my drawers and I'll tell you).
Another problem  is : do you have the crown ?
If you don't have the crown ... I'm not certain that watch deserves the effort and money you could put in.
If you still have the crown and your mate really likes it you could swap the movement and put a better one inside :
Miyota 8215 ($50 and you can keep the same handset) reasonnable choice
- 2836 clone ($90 and you must source a matching handset so spend more $) the best choice in my opinion if your mate wants to keep the watch ... don't forget you will have to modify the dial's feets.
- wait for a used ETA2892-2, source a matching handset and put that in the watch case ... then search for a 1120 Omega rotor so that that fake Omega watch can have a faxe Omega movement inside ... I'm just kidding of course
But, once again, the question is "does that watch deserves the money and work ?"
You should show us the face and some details.
Go to http://www.ofrei.com/page1119.html and scroll down to the DG3806PB movement. Similarities to yours are there and so, yes, this is a Chinese movement. [You've only shown the rear of the watch so the exact model may be different depending on the features; double check through other movements]. Towards the bottom of the page you'll see stems advertised to fit these DG movements for $4 a piece; I'm sure there are other sources too.
I was replying but got interrupted mid way through so hadn't seen that @manodeoro had already helped in the identification for you whilst I was writing and before I hit Submit!
Edited by WatchMaker
The kind of informative and comprehensive replies that are typical on here - thanks so much.
Yes it unfortunately doesn't have a crown either, so I'd need to source a screw down crown that fit as well, which might prove a little tricky.  I kinda like the idea of swapping the movement for another though, might be a fun little project.  Will have a think on all this.
As you asked, here is the front of it.  I actually *gets ready to run* don't think it looks too bad :/  Ok, when you get in close you notice actually the numbers don't look quite right, the bezel doesn't line up exactly at 12, but at a sideways glance.....
No?  Anyone?
@MattWatch you're welcome :)
All the movements I've listed are the same diameter of 11.5 lignes but only the Miyota 8215 has the same hands specs (H : 1.50 - M : 1.00 - S : 0.17) than the DG2813 ... you can check those specs on ranftt wach archive.
I'm just looking at the watch face and I don't think it deserve much more than a 2813 so you'd better source a stem and crown and stop there.
In addition to the copy errors you already pinpointed you could add that the Helium valve is misplaced (not certain but 90%) and the pearl is yuck.
But that watch is still a nice one so, even if it's also an illegal one, as your mate like it you should put it back to life.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
