I'm hoping someone can help me I have a BMW Motorsport Ice-Watch and the chronograph pusher has become loose. You can actually just pull it out so i'm guessing its definitely missing something?
I can no longer change the date or time - Would I be right in thinking its missing a circlip or spring?
Thanks guys i'm a new member here and appreciate all your help,
2 hours ago, oldhippy said:
Many pushers are held in by a tiny circlip, so you could be right.
Thanks for the response, I did think that! My local jeweller is booked up until after Xmas and I'm thinking of buying a cheap Ice-Watch to see if that is the case £10 might cost that to replace with labour etc anyway.
