Eterna sonic electronic
Latvas
There must be a way, [emoji848]
Its a tuning fork movement so i cant remove the hands and dial before the electronic part are removed , as it would ruin the index wheel [emoji848][emoji316]
Looks like a split stem. Take that out and the movement should come out easily
thats sounds legit, but how does a split stem work, is it simply a matter of force ?
The style of case construction definitely looks like the movement goes out the front.   A clue that the movement comes out the front is if you turn the case with movement upside down if the movement seems like it's loose in the case that would be an indication that it will fall out once the stem is out of the way.
Split stems are interesting 90 some percent of the time you just need to pull hard on the crown. The split stem will then split apart the movement will fall out everything works nice but tiny percentage of the time that's not the way it works. There are some split stems and if you do a search we've had a discussion about this before. Some of the split stems don't split apart by pulling they have to slide apart. Usually on those type you can see the stem the dial is made in such a way that you can see the stem to get it lined up to slide apart. Otherwise you turn the movement upside down slowly rotate the crown if you're lucky it just slides apart the movement falls out. Otherwise they make special tools for pulling the crown out or tweezers between the case of the crown is give you some leverage.
Let us know how you get on. Be brave!!
It went very well
There was a part of the electronic circuit that was defective, the readings were bad according to the service manual
Fortunately i had a tissot tissonic with the same movement cal 9162 where it was the other part of the circuit that have failed, so i simply mixed the parts,took some new readings, and all were good to go, oiled and reassembled the piece, and with some gentle taps it sprung into timekeeping again , humming strong ,and with remarkable precision,under 1/2 sec per 24 hours too fast.
Many thanks for the help from you all
Il post some pics soon
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
