Seiko 7s36 movement
icebeak
normally when timing a fully wound up watch especially if you just wound it up you let it settle down for 15 minutes to an hour. A lot of it depends upon the watch. The problem with this Seiko is their tech sheet doesn't tell you how many times you have to shake it to wind it up. then it's nice if you time in more than one position I'm guessing you had either dial down or dial up? so dial-up and dial down will be nice they both should be the same and a wristwatch one crown position like crown down as that's a common position for wristwatch. sometimes problems only show up in one position which is why multiple positions are nice.
then one of the minor downfalls of the Chinese machine is it would be nice to be able to here the watch? The reason is it be really interesting to know what the watch sounded like when it was producing that strange waveforms?
so after you'd demagnetized and the problem went away if you repeat what you did to do this the first time does the problem come back?
then interpreting the timing machine? It's kind of like reading a crystal ball at times while there are guides out there waveforms are not always exactly clear on what they're trying to show it to us. For instance if your watch was running fast when it did its bizarre thing I would refer you to the two videos below. The first one explains about the condition and the second video he has a newer timing machine so you can visually see it on the newer machine and the real audio as that machine has audio output not beeping like the Chinese.
https://www.youtube.com/watch?v=Rcqrb3_vin8
https://www.youtube.com/watch?v=7KNTrHVD088
what makes you waveform interesting is the line is relatively straight except when there's a problem and the numbers indicate the watches going slow?
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
