Hello. I’ve been asked to replace the capacitor in a citizen E210.
1. Would it be a capacitor or a rechargeable battery
2. What size would it be.
Any help appreciated
Capacitor. http://stsupplyonline.com/catalog/citizen-capacitor-29569-e210-e310-e600m-e610m-e670m-g900m-m107-u600-p-12699.html
You can find a 295/69 on Ebay or cousinsuk .
Edited by rogart63
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
