So here goes, apologies in advance for wrong teminology.
Iv'e learnt that three out of the four stopwatches I have are broken because the very ends of the balance staff are broken off either at one end or both ends, and one watch was not working because of a damaged main spring, although i havent sighted the mainspring in this one its just an assumpion because i can wind it forever.
I managed to strip and clean all the parts in a small cheap ultrasonic cleaner i bought from amazon with just a soloution of fairy liquid and tap water as my cleaning agent.
So i have a balance that seems to work from the broken mainspring watch and i put everything back together using all the best bits from each stopwatch, and added a little oil to the jewels and success, the watch now beats.
However only when i hold it a certain way. Its stopping when held face up.
And its accuracy is pretty poor.
I am now tempted to buy a new balance assembly as i have tried putting the hair spring and wheel onto one of the other bridges just incase it was because of a misaligned or damaged jewel and it is still the same symptoms. I think i saw new ones on the cousins uk website if anybody could tell me if a new one would come as the whole assy of spring, wheel, bridge. Or just spring and wheel or what?
I did manage to break one of the small levers that holds a wheel that operates levers for stop start reset but I used one of another watch i think it might have been rusted in place or bent slightly anyway.
15352925135675289547008007203728.thumb.jpg.011c0a8448539f8863321d49f04ce9c4.jpgI also managed to pop out a main spring from its barrel which was very annoying
So my questions are;
What can be done to improve accuracy?
What can be done to stop it stopping when face up?
Should I get a new balance assembly?
Thanks in advance...
  • Similar Content
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
