A chronograph ETA quartz movement i am fixing. Have serviced it and that was not an easy thing. But think i got it working. Found a part of the stem in one of the rotors.  But do you know if i need to set the hands perfect or i can adjust that after. Like a 7A28 or similar movement . Where you pull the crown out and adjust the hands to zero at twelve.
Up and running. Puuuuhh . The lower chronograph hand is slightly to the right. So need to adjust. But will do that later when i change the crown and crystal. Have to do something about the bezel as it is stuck. Probably lots of dirt and rust in there. Maybe i can see better when the crystal is off. DSCN0583.thumb.JPG.f963081664fe003b4d0b7f0d436e6bed.JPG
Edited by rogart63
