Just wanted to ask what are you useing to film your videos on YouTube .they turn out really good .is it a web cam ?and what kind of demagnetizer do you use ?looking to get one
Hi Daniel,
A Canon 600d with a 60mm macro lens.
and you will see my demag tool here (made by Elma)
Hope this helps :)
Excellent Daniel, you won't be disappointed with that kit. What movement did you finally buy?
Edited by bobm12
Yeah! Me too. A Certina movement as a matter of fact. I haven't started working on it yet. I got sidetracked by an UT 6498 equivalent to the ETA 6498-1 which is another option for that tool kit...and of course by about 15 other movements I had laying around the house and/or from ebay! I couldn't make that brand new movement my first victime at the time.
In any case, once you case it you'll love it! You'll see!
I did all 3 levels at the same time...I can say I'm still going back on and off. The trick is to do the whole watch as it "should". By having all three levels you end up servicing and regulating the first and second movement they tell you to work on. In the end, the watch you make is completely ready for normal wear.
If you only do level one, the movement is not fully serviced. Normally you will either loose something or break something that has to be replaced (make it an AND sentence for wost case scenario). When you finally assemble the movement and "build" your watch, that movement is not properly clean and lubricated for everyday use. The wear and tear on the parts are excesive and to correct that you need at least level 2.
After learning how to clean and lubricate (lv 2) then you adjust the watch in Level 3. Then your watch should be a dependable and accurate timepiece!
So in a nutshell, that's the complete class experience!
sounds like this is going to be fun .just cant tell the wife that I still got to order the lvl 2 and 3 kit yet he he he he  :P
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
