Greetings all!  Reaching out for some help regarding a ‘70’s manual windup Timex Snoopy watch that I need to remove the second hand (clear plastic disk with tennis ball graphic).  There is a tiny brass fastener on top.  Can anyone explain to me the process of removing?
Thank you so much!
Rick
Edited by rlpjwright
Update
I repaired one a few years ago by changing the movement. The one I repaired had a football on a clear disc. If I remember correctly the disc was just friction fitted much the same as a normal hand. I removed with hand removal levers being carful not to bend the disc.
Those came in two different case sizes and different dial colors.  But all the same in that yes the disc is just friction fit.
I serviced the one that has the "Blue Jeans" dial a few month back.  To remove the disc, I slipped a pair of tweezers under it and lifted it right off.
Here is another one I have.
