Trying to service an AS2063 automatic movement and have it stripped down to just removing the shockproof details.
Ran into an unexpected problem with the variety of inca springs on this device. Releasing the springs ends works just as with the common lyra shaped ones but these won´t show any sign of being released or spring up from the end stone as I´m used to see.
I suppose there’s something on the hinge side of the spring that locks it in place in spite of the ends being free?
Afraid to brake anything when/if trying some ”force” and would appreciate any feedback or hint on this to me unknown design.
/bsoderling
/bsoderling
Those springs are a real bugger. They work like a normal incabloc spring. Seen those on some ETA movements also. If they are the same. I have a few if you run in to trouble. But think they are a pain to put in.
Think the name is lubrifix 66.   They should be called  lurifax instead :)
Edited by rogart63
So no magic button hidden somewhere that will pop them open :-)
Guess I will have to get my most super magnifier glass on and get real to close to see what’s going on....
Thanks for the kind spares offer if things go south, always appreciated.
Quick update...
High power magnifier and a sewing needle soon made me realize that the ”hooks” on these springs are much longer than what I´m used to from the regular inca-springs.
In my previous attemps I had actually never released the spring, just shifted it slightly.
I attached a photo for anyone interested ....
    • That's just it. I am actually looking to see if I can replace the second wheel on a Omega 3220 which uses the ETA 2892-A2 as it's base. The 3220 actually has a push fit chronograph driving wheel on the pivot rather than a second hand. Not certain that this would be a direct replacement but it could be worth a shot versus paying $150AUD for the Omega part.
    • Yes, being lathe deprived is a problem that I have, so obviously interested in solutions that don't require one.  The Balance Staff removers are interesting. I wasn't sure if you could get them in a size to suit a typical wristwatch movement, I thought they were more suited for pocket watch balances.  I was surprised to see a staff just pushed out with a Horia tool but I guess if you get a very close fitting stump it would potentially do the same amount of damage as a remover (the only difference being that the remover seems to clamp down the cross arms of the balance immediately surrounding the staff). I did read somewhere that Rolex (who apparently recommend this) balance wheels are harder than others. This is maybe one to try on already scrap balance.
    • Can you confirm the movement number you're working on.
    • Just checking terminology here. When a pivot is described as having a certain height is that measured from pivot tip to pivot tip or from the face of the wheel to the tip of the extended pivot? I have a bit of a strange one that measures closer from tip to tip but not from the wheel face to tip (I get 3.1mm from face to tip and about 3.6mm tip to tip when badly measured with my Vernier calipers)
    • This is the best option - if you have a lathe.  For those of us without, I use a Balance Staff Remover as shown in your pic. Using this, I have not seen any damage to a balance.  Rolex recommend just pushing it out as their balance arms are quite hard. But, as @Klassiker suggests, do a search of the forum and you will find plenty of discussion.
