Skagen Hagen SKW 6217 BATTERY CHANGE
I own a Skagen Hagen SKW6217 watch.
The battery just died in it.
I can't seem to figure out how to replace it. Read online about it's top load design and unit body form.
All I see is a screw at the back of the watch.
All the jewellers I have taken it to are unable to replace the battery cos they can't seem to open it. Is there anyone who can help guide me on how to open it?
Some models of Skagen are sneaky, i did a little bit of googling for this model but could not find it. I was considering that it might even be solar powered, i've come across two skagens that were solar powered but did not state anywhere on the outside of the watch that it was, and they both had that line on the back with the model name in the lower right hand of the line.
Honestly if you can't find a watch specialist who's competent to do this I strongly suggest returning to manufacturer.
http://www.skagen.com/us/en/service-information.html
However, I will say that it is very likely that the crosshead screw on the back comes off to expose 'the setting lever' which can be pressed to release the winder and from there once you have the front off it should be possible to drop it out.
oh, i just found it actually, okay looks to be regular quartz, not solar. and the front should be removable by prying off, it's also a little less expensive than i assumed so I could understand some reluctance in going through a Skagen workshop, however, I will re emphasize this could go horribly wrong for you without the right experience and tools.
6 minutes ago, Ishima said:
oh, i just found it actually, okay looks to be regular quartz, not solar. and the front should be removable by prying off.
Correct. I did not check, seems like the bezel is removable, no pump needed. I agree with Ishima, do not try DYI that, too easy to scratch or otherwise ruin it.
skagen-hagen-black-dial-black-leather-me
This is enlightening!
Prying off the face would need something different from the regular prying knife in watch repair sets, right?
You need a sharp blade, which is kind of dangerous. Bring it to a watch repairer, not a jeweller.
Had really nasty experiences with watch repairers. That's why I picked up watch repairs as a hobby and to try something new for myself. We learn everyday.
Will look for a sharp blade for it then.
But there is no bezel. Do I just pry at any point after taking out the crown?
Just a day on this forum and I made huge success. I was able to open the watch (there was actually a bezel at the top but hard to see) swapped the battery (621SW).
Had a tough time closing it back since I don't have a watch press. But I padded the nose of my pliers and applied gentle force till the front snapped shut.
Watch is working great now.
Thank you @jdm and @Ishima
  • 4 weeks later...
Hi, I have the cousin to your watch (the SKW6216). Removed the screw, took off the crown.  I've managed to pop out the glass like the video instructed, with the pump method but the bezel was in the way of the everything else. Where was this bezel at the top you found? I feel so close yet so far from replacing this damn battery. :wacko:
Look closely at the attached photo. Hope you can see what I am referring to.
  • 1 year later...
Hey! Did you need to remove the stem before taking the front off? I was struggling to get the stem out!
To remove the mov't you have to remove the stem first.This is true virtually for any watch.
  • 2 months later...
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
