My wife took my A Lange & Sohne, 1908 pocket watch with a 14k Hunter case, to a local jewelry store to get the glass crystal replaced as it was broken when the watch fell out of a cabinet about 4 inches and cracked the glass. When I got it back, they had replaced the glass with a plastic cover and the lid would not spring open as it had always done. I have no idea why they even had to remove the movement from the watch to replace the glass, but they did, and when they tried to put it back together, they did not put the lid spring back in place properly and it will not stay in place.
I have put it back, but when I open the lid, the spring pops back out, apparently the same way it did to the jewelry store guy.
There are 2 tiny square lugs inside the recess where the spring goes, and it looks like the spring ends should hook behind them, but I'm not sure since I can't seem to get the spring to hook onto anything at its ends, the only thing it does when I put it in the recess, is it catches behind the lid hook which is shown in the picture, but the ends remain free which I think is the problem since it looks like the ends should be captured and held into place on the protruding lugs. I don't think the designers intended for the lid hook to be the only thing holding the spring in place.
Can anyone give me a clue as to why this spring will not stay in the recess once I get it installed and instead just pops out which leaves the lid without anything to open it?
Could the jewelry store guy have broken off something in the recess that is no longer there, but was originally, and without it the spring now has nothing to hold it into place?
Any suggestions would be greatly appreciated.
Having looked at the pictures I would guess that the spring is held between the square lugs in the recess under its own tension. It also looks like there is a inner retaining ring on the inside of the bezel.
These watches are of such value I would not attempt a case repair  myself I think the best option for you would be to find a case restorer and let them do the job rather than risking damage to what is a very valuable watch, although it may prove expensive the value of the watch will far out way the cost of repair.
In short leave it to an expert.
Having the wrong glass is a good start. It should not have plastic; the height could be the problem. Take it back, tell them to remove the plastic replacement get your money back and take it to a reputable watchmaker. One other thing these plastic replacements expand when fitted causing the plastic to rise in height, the proper glass replacement cannot.
wis1971 is correct on how there held in place.
Edited by oldhippy
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
