Eterna 629
rogart63
Need to find a new balance cook and a new balance for a Eterna. Says 692 on the movement.Someone has glued the balance spring and the adjustment to the balance cook :( But can't find anything on Eterna 629?
Why can't something be easy?
Found this .that says Eterna 629. Unfortunately it's not available  anymore.
Edited by rogart63
How many different balances can there be. If i could find a balance with the right height and a impuls that moves the pallet fork. Has the same frequency as the 692. Think it's 18000 . So the hairspring has the right length . Do you think i can get it to work? In don´t the owner mind if it doesn´t run in Cosc . But could at least go within a minute a day.
I found one but not sure it works yet.. As the stud that sit in the balance cook is 0,5 mm and i am not sure what the hole in the bridge is. i didn't have a drill . Put will take a look tomorrow. If the endskake is to large can i move  the upper or lower  jewel? The impulse jewel moved the  pallet fork so that looked okay. But you  never now ? Hairspring to long what do i do then? Would make it 18000 if it has been i an old ETA movement right?
Edited by rogart63
    • Fast responses - thank you. Yes, I mentioned the 18000bph to illustrate that it's not a matter of touching coils, over banking, shortened hairspring etc. I even took off the platform and temporarily fitted a another NOS one also with 8 leaves and beating 18000 but the colossal gain is the same. I'm resigned to buying and fitting a new Gorge platform plus a 7 leaf pinion escape wheel but only if I think it will work; otherwise it's a waste of £200 and a couple of hours work. Hence the underlying question is: all other things being equal, what would the timekeeping effect be? Is it a simple 7/8ths as fast? Logic tells me it is but can it be that linear?
    • Sorry to jump in here guys, but I've read through this whole thread and it seems there are a lot of people who think joining Facebook means everyone will have access to their lives. You could make a Facebook account with a fake name. You could even use your real name if you wanted to and set it to completely private so people can't even find you in a search and you don't have to add anyone as a 'friend', so you won't see anyone's posts. Literally use it to join a group full of members of this site. Admins could even set the group to private and require a password of some sort to gain acceptance into the group, so you can be sure that it's only members of this site that get in. @tomh207 is right, the form with email addresses and names is a bad idea. That will be abused by scrapers. Facebook is only as personal as you let it be. You can be completely anonymous on there if you wish. Don't think of it as Facebook. Just think of it as a watch repair group as that's all you'd use the account for. It doesn't even have to be set up with your current email address. Make a random one on Gmail or any other free provider just for the Facebook account. Tagged you by accident and now it won't let me remove it 😂 @Neverenoughwatches
    • Hello and welcome from Leeds, England. Plenty of clock people on here to help you out.
    • Hi I'm a new member.  I recently pulled a Wakmann 8 hour clock out of one of my small airplanes.  My hope is to get it working again.
    • I have a timex urban command (digital watch with indiglo). Are you aware of any dangerous substance or material that I can come in contact with if I disassemble the watch? For example I read that the indigloo is made of luminescent “indium tin oxide” (as reported here https://www.chemeurope.com/en/encyclopedia/Phosphor.html) and that this material can cause irritation to the respiratory tract If inhaled (https://en.wikipedia.org/wiki/Indium_tin_oxide). Any other stuff I should be aware of? Thanks in advance for your answers.
