ETA 2824 Crown Replacement
Wesley881
Hi all - I have a Fortis Fleiger on the bench and the crown, which looks to have been replaced once already, has worn out. I beleive these crowns are supposed to wobble some by design. Are there measurements I can take to find a replacement? It is also a screw down crown. 41dbaf084aed2011c9a059360eff4e17.jpg
Sent from my SM-G920V using Tapatalk
Hi all - I have a Fortis Fleiger on the bench and the crown, which looks to have been replaced once already, has worn out. I beleive these crowns are supposed to wobble some by design. Are there measurements I can take to find a replacement? It is also a screw down crown. 41dbaf084aed2011c9a059360eff4e17.jpg&key=02ed7a8a91bd45b52e30cbe4bb0a5074bb6f45ae280bfbbe894acb81ad1e9bbf
2 hours ago, Wesley881 said:
Thanks much for the info thus far, I havent replaced a crown of this type before so the picture is getting a little clearer. It does seem like parts are missing. Are the tubes pressed in?
How does the tube in the watch look like? I wonder as i can't see any gasket in the crown. Internal or external thread on the tube in the watch.
Looks to be external thread on both diameters of the tube, with an internal gasket. The crown contains a face seal gasket. I've attached some more photos. Needs a good scrub.576b5626d058f1f0347024eb3888a0e8.jpge05faf6b85eeddb6dd6914222e482506.jpgb78eb05a09743a913e3c4aeed49df49e.jpg8dc4245daac665fd7701e9f4e0fcb0fb.jpg
Looks a bit like a Rolex crown. Could be easy to find or  could be tricky.
Or the best maybe would be to contact Fortis and see if the could help you out?
http://www.ebay.com/itm/FORTIS-steel-crown-tube-for-FORTIS-Flieger-Automatic-34-mm-blasted-/182558513487?hash=item2a8155d94f:g:wnQAAOSwzHxZvwVR
Is this what you look for?  Sorry for linking to Ebay . But was difficult to show in other ways.
I think thats the correct set (internal thread for crown) and what I have is a replacement, perhaps a generic Rolex. I ordered some aftermarket parts for this movement. If they dont fit, will have to spring for the $70 factory parts. Thanks for keep an eye out, I'll follow up when parts arrive.
Hi, juat wanted to post an update that I got the aftermarket Rolex style crown in and it works well. I had to tap the case for the new tube and locktite it in place and make some adjustments to the stem and all is well. Thanks!
Most of the way through reassembly and I have mysteriously lost part number 161 the center tube...Are these easily sourced for a 2824? I found several on the Bay and one is titled 2800. Does that mean it fits all movements with a 2800 series prefix? I'm new to this taxonomy.
Best,
C
Best,
C
Not with you there? Where does this tube sit?
Its like a guide tube for the main wheel and is usually lightly pressed into the center of the main plate. I did, however, manage to find it!9631463a3376a003c5171007329d4e23.jpg
 I never remove that when i service a ETA movement . But have occasionally changed them when they have been damaged.  Looking good your watch  with the crown.
Edited by rogart63
    • Many would disagree: https://www.rohm.com/products/faq-search/faqId/234 https://uk.farnell.com/c/semiconductors-discretes/transistors/bipolar-transistors/pre-biased-digital-bipolar-transistors https://uk.rs-online.com/web/p/bipolar-transistors/8232832P?gb=s https://uk.rs-online.com/web/p/bipolar-transistors/0580240?gb=s (RS don't have a specific category, but over 1000 "digital transistor" items).
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
