Greetings from Norway [emoji16]
I am pretty new to this hobby and my first project is to get an old Omega Ladies watch running again. I.e cleaning and changing the glas.
My problem now is that I find it impossible to remove the stem and crown. Can anyone please give me some hints on how to do this?
Attached is some pictures of the actual watch and one picture of the movement that I found on the Interweb.
ad24779d365cdc80b2fbbd9fc63568fc.jpg&key=027baf51bc999ca8cad561adf4b9e94a4641d06a99025d88d06f1210e687b53d
7198e01cc23ce91a5e5cdef570e8b236.jpg&key=259dfad47fbc03a1c18a29a598b4befeb69a6e26e1faa0f2557e5b3c3467c5cb
Try pushing the button remarked while you pull the stem from the crown outwards.ce4b9a8512ad89f9b59d04748636ca43.jpg&key=5c74e61da8af49edb79265bdbf76e4680d43bf5ae5a870b0c091666611f24890
Enviado desde mi SM-N910C mediante Tapatalk
Thank you very much [emoji1303][emoji1303][emoji1303] I had to put the screw back in and then push.
Sent from my Commodore 64
Well, is more of a post, it have no thread, will go straight down, is also the pivot for the setting lever on the dial side. Be careful don't apply too much pressure just enough to make it free the stem.
Best regards.
One last question:
Can anyone tell me the name of this watch?
The serial number is: 12884489. From that I understand that it is produced in 1951.
What I am looking for is a new glass and a new dial.
I'm going to stick my neck out here. If that is the date of the case then I think the movement is a replacement.
Any good suppler of watch material should be able to help you with a new glass. A genuine Omega glass will have their emblem in the glass on the centre, but I do not know if that applies back in 1951.
If you want the dial restored then you need to find a watch dial restorer. It will be very expensive.
15 hours ago, EtronX said:
One last question:
To find the name or prefix for this model the inside of the case back will tell you more than the serial number ladies Omegas using this movement are as follows :
CK 2787, CK 2873, CK 2524, CK 2927, OT 2929, OJ 11018, BK 2870, CK 10983, OT 2983, CK 2967, OT 2683, OT 2683, OT 3949, CK 2510
The calibre 244 was developed by omega in 1949 but became widely used from 1950 onwards  and was based on the 1938 calibre R13.5 15 jewel with the addition of shock resistance and two extra jewels.
The dial and hands look to be too early for a 1950's watch and as oldhippy as stated it could be a replacement movement as a calibre 244 would be an ideal replacement for a earlier calibre R13.5
Edited by wls1971
Roger that. Thank you very much for the reply :-)
The name inside the case for this model is 2668-2. I have Googled it and the name that comes up is CK 2668, although I find no information about it. Not even on Omegas homepage.
Thank you for the reply, oldhippy.
I checked the glass. No emblem on it. I guess I can try to find a domed glass with the same diameter and fit that in.
Yes that will be fine. As there is, no s/seconds hand a low dome could do the trick.
Time to hit Cousins :-)
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
