Re - Elma Watch Parts Dryer
daz
Hi all,
Bought one of these recently so thought I would share my experiances  with it so far...
My initial thoughts on it was that it was way to expensive, but as I am servicing a lot of pocketwatches and wristwatches I thought it would be a good investment
anyway I took the plunge and placed my order and upon using for the first time I was pleased with the performance, you have 2 settings one for hot and one for cool
A WORD OF WARNING!!!
IF YOU CHOOSE TO USE THE HOT AIR SETTING MAY I SUGGEST THAT YOU NEVER PUT JEWELLED MOVEMENTS ON THE DRYER ON THIS SETTING
AS IT GETS VERY HOT VERY FAST AND COULD QUITE EASILY DO SERIOUS DAMAGE TO THE JEWELLING, I ONLY USE THIS SETTING FOR PIN PALLET MOVEMENTS
AND USE THE COOL SETTING FOR JEWELLED...
The Instruction manual does say not to use with flammable chemicals so I just wipe any residues off the cleaning containers and place them on the grid and all other plates, bridges etc..
are placed on the grid and it works a treat. On the whole it is a good buy but is very expensive for what it is....
Hope that this gives an insight
Best Wishes
Darren
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
