Need Help With Stem Removal
This is a friend's watch. She needed a new battery and I offered to change it. When I removed the back, I immediately knew this watch had issues. Someone had put a sticker over the battery to hold it in place. When I removed the sticker/battery,the battery contact was bent and every time I attempted to put a battery in, it would pop out!!! I had to take the watch home and finally got the battery to stay in. Then I was unable to pop the back back on, so I had to use a watch press. I finally had the watch ready to be cleaned on the outside and scratches buffed out, I went to set it to the correct time and guess what.... the crown broke off!!!! OMG!!!
This watch looks a little different at the stem and I have tried to remove the stem by pressing a dimple, but no go. I'm afraid to put too much pressure on it and I need to make sure I'm pressing at the correct location. All I want is to get this watch back to my friend in working order!!!!! Thanks in advance for any advise!!!!post-278-0-00337400-1406587997_thumb.jpgpost-278-0-27811900-1406591310_thumb.jpg
Hi SuzyQ,
Welcome to the forum. Help is on the way!
And don't worry, all will be well. I understand your frustration but patience is all powerful when with watches!
So, in those cases, I usually use 2 tweezers to pull the stem out. One to push the stem release lever (usually through a hole or a little "button") -- I believe the hole on the left of the stem in the picture but it is not too clear -- and the other tweezer to grab at the stem proper and pull. This pull is usually by parts since there is not much room for a full pull of the stem. You might even have to wriggle the tweezers side to side...Be careful since you are working inside the watch! In any case, that's what I do. Maybe other members have a better way of doing it?
I hope some of this helps!
One question from the picture, is that a portion of the crown still attached to the watch or just the tube where the stem fits in? Is part of the stem still in the crown where it broke?
Robert
The center of the crown is still attached.Just the outside of it broke off. I posted a clearer pic of the watch. Thanks Robert. I have tried two tweezers. Can you look at the third pic I posted and see if you can help me??? Thanks bunches!!!
Is there an arrow or some indication next to the stem to the left front or is it simply the movement information? How about to the right between the stem and the battery? There is usually an indication about the right spot to stick the tweezers or a small sharp object to release the stem. On the other hand, it seems that you can still grab the stem by holding the portion of the crown still attached to it so the 2 tweezers trick might not be necessary.
Remember to puch the release lever and pull the stem at the same time...kind of gently.
Edited by bobm12
Thanks Bob for helping me. The writing is:
AL 21C
E P H
NO JEWELS
and the other is:
HONGKONG.
i do not see an arrow or indication where exactly to press. There is a "dimple" that I have tried to press, but no release. I don't want to press too hard since I am unsure if that's the place.
I think SuzyQ that it is more a hole or even the tip of a lever than a dimple (although dimple could work too) and you have to stick one leg of the tweezers in, gently and push. You will feel you are pushing something (springlike) down. At the same time the stem will become loose at your pull of it (it will detach). If that little end or bright point in the front left of the stem doesn't give, try another hole alonside the stem, gently, but look carefully first before you damage anything.
Thanks Bob. I've inspected the watch with my 20x loupe. I've gently tried several places. No go.... I've removed stems before so I know what the "spring" feels like. I'm a novice at this, but I enjoy working on character quartz watches I get from junk stores, online auctions, and yardsales and this one had been a pain!!! Murphy's law: if it was my watch, I would had it ready in one day!!! LOL I'm not going to try anymore tonight... maybe I'm just not holding my mouth right!!! LOL Tomorrow will be a new day!!!! :sleep:
Hi SuzyQ and welcome to the forum.
Sometimes the stems are quite stiff to operate. I would suggest that you use a small pair of narrow nose pliers to push the stem up and down from the running position to the setting position. When you do this look in the small hole to the right of the letters AL 12c and in either the setting position or running position a small lever with a dimple in it should appear. When it does, press it and the stem should come out. If that doesn't work, check other places, but remember that you will have to have the stem in the correct position to operate the release.
Thank you guys, I'm not too good at explaining! Great support! I wonder where Lee gets all the pictures! Amazing!
By the way Lee, I'm always visiting your blog, nice and to the point. Thank you for having it.
SusyQ, with all this help you have to have that stem out for sure! Tell us about your progress and please don't hesitate to ask away! It is a beautiful hobby.
    • Why is it when that little voice says, "This is a bad idea," we always want to talk ourselves out of it? I had the low blood sugar jitters earlier, but insisted to myself that I'd be able to oil an especially tiny cap jewel on my friend's Omega 1001. With lots of concentration, I nailed it. But when I put the hole jewel on top, it was too much oil and it squoze out everywhere. It didn't spread on the cap jewel much thanks to the epliame I'd applied, so it was more than it looked like from the top. Back in the cleaner, dried, re-epilamed, dried. Time for a second try, but now I was more shaky even than the first time. "This is a bad idea," my brain told me. "Take a hike, brain," I said as I watched the oiler jiggle into my microscope's frame. And just like that, the jewel was a tiddlywink and flew out of sight in the blink of an eye. With a strong UV flashlight and the waste of a lot of time I did find it on my desk, but that's some stress I didn't need in my day. So friends, listen to your body, and listen to your brain when it tells you now's not the time for precision work.
    • I dont think Hector means there is an issue with the hairspring at the collet, only that the collet is not centered over the jewel hole. You can check this by unmounting the hairspring from the balance and recentering the collet with the balance jewel. If the coils remain undisturbed then i believe it unnecessary to dismount the collet and only adjustment at the stud is needed to bring the hairspring to shape. If any of coils have been accidentally bent then reshaping of hairspring separately would be required.
    • @HectorLooi Thanks.  I do have a microscope. But no camera to show what I see in it.  You are correct that some coils overlap. In particular the outside one where thr regulator pins go  overlaps the previous one. I will try your suggestion.  I am surprised that there is an issue with the collet as I don’t see how I would have messed that up.  I didn’t think the impulse jewel is damaged as I can check it in the microscope. I meant that when I put the balance I am always wondering if I managed to set it correctly in relation to the fork.  Thank you all. So I think I will take @HectorLooi advice and note that the hairspring needs fixing and go practice with my second ST36. In any case this one also has the setting lever screw broken in the setting lever.  I think I’ll also order a dial, case, hands and strap to make a watch out of that second movement.  I see a bunch of them on AliExpress or eBay.  Anybody has recommendations?
    • I thought that was the knee bend , start of the end curve Rob
