Can anyone identify this "Nugent and Wells" pocket watch movement
Hi Rich, the main problem with the balance is if the roller is from this movement. Did Yoy try if the balance interacted correctly with the lever? You can use suitable (by size) balance/hairspring couple from You pile of balances, but the roller must be for this lever (original for the calibre). Not that making roller is impossible, but it is easier to have one. -
Its ok blueharp the pictures you provided earlier of the 3 keyless components, the setting lever, the setting lever spring and the yoke plus the brass cover plate should be enough. If they are not listed anywhere then you are relying on any lettering on the movement or someone that just knows the movement from experience. -
Thanks jon, that would be my only option but i have bigger problems now with this one -
By nickelsilver · Posted
I have only been in one head with the lever closer, and that was a long time ago, but I don't recall anything attached there. Does it function? I have an old ratty head I pulled apart to give an exploded view, with the tools necessary to take it apart. You can see the large spacer, then the small inner spacer I made in the other pics (standing up with the large one, and on the spindle).
