Omega 1012 Stem Problem
I have a problem with my Omega 1012, where the winding stem doesn't stay in place, it can be pushed in and it winds the mechanism, but if you go to pull it out to change the date or time it simply comes straight out.
Any help will be appreciated :)
Hi,
  You could have one of several issues. The easiest one is that stem just isn't set completely under the set lever. Might try to push down on set lever pin and push crown a bit more into watch, gently. This condition would still allow watch to be wound but since stem isn't set properly it will just pull right out. Other issues are a bit more complicated. Set lever may be broken. You may be able to check this by removing stem and looking into the hole and trying to see the tip of the set lever that holds stem in place and it also is what helps move works to change position from winding to setting. Also the set lever spring may be worn out and not holding proper tension on set lever. I also suppose it's possible that the end of the stem may be broken or eroded allowing the stem to slip under the set lever. Judging from the picture alone my best guess is that stem just isn't into watch far enough. Crown should fit snug to case when all the way in.
Hope I was of some help,
Charles K
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
    • I only watched the start, but he's out on magnification by a factor of 10. It's 7X to 45X, not 450X
    • It's one of those tools like screwdrivers and tweezers, where it's worth spending more for the quality. And it gets used all the time. At about £20, the 4040 is not expensive for Bergeon.  When putting a watch in dial down, you have to be careful not to catch a sweep second hand, but once secured, life is easy - two hands available to work on the stem.
