Hi all,
Two days ago I was cleaning an Elgin kwks watch. It runs smoothly right after the few key winding. I let it run for 10 hrs then put back the dial and hands and put it back in it case and starting to time testing it. I've notice that it's gaining about 30' within 4-5hrs of running. Does anyone know how to resolve this issue?
Thank you all, any advise would be very appreciated.
Teng
Try de- magnetising it before delving deeper.
Hi Geo,
You mean de-magnetized all the parts or just the balance wheel assembly?
Thanks
Teng
