Quick question,  where to buy old but new mainsprings for old pocket/fob watches?
I'm in need of one at the moment as the arbour end snapped off, my measurements are as follows
height 1.95mm
thickness 0.24mm
approx 300 mm in length
inside diameter of barrel is 41mm
now ive hunted through cousins with no success, ive also tried putting in the exact measurements of smiths ingersoll dollar watches mainsprings but again im coming up with nothing.
anyone have any ideas please cheers
Bit confused, Cousin's search tool doesn't seem to be working right now, but you can see what they have here https://www.cousinsuk.com/product/upto-200mm-height
More confusing are the dimensions you have given. Is this a regular 30-40 hour lever escapement pocket watch, or an 8 day watch? A 41mm barrel is the size of a watch, and whatever the barrel size, 300mm sounds short.
You may find that you don't have the right spring fitted, and you need to work out what should be in there.  There is an excellent expanation of how to do that here http://www.vintagewatchstraps.com/blogmainsprings.php. I can't remember if it tells you but you need a spring heith with about 0.2mm clearance to the internal barrel depth.
Photos would help if you need more advice, and we all love to see them anyway.
Ooooppps,  was meant to read 14 mm in diameter, the movement itself is a cylinder escapement, I had a thread asking the make of the movement not so long ago, I will try and copy the link into a thread  shortly to helpyou abit more ok.
Ok, so for a 14mm barrel, the calculator says the mean spring thickness would be 0.17mm and length 439mm.
A 0.24 thick spring will give more power, but will have to be shorter to fit the barrel, and is only going to give you 4.5 turns, so unlikely to run for more than 20 hours or so. You aren't going to find a spring this size so you would need to cut one down to get this if you really want to.  I would be inclined to use the thinner spring which will give you the right number of turns.
Cousins search is working again now... not sure if it was me or them.
There are very few 1.95 high springs, so in the 1.9 range, GR5607 is your closest bet, assuming you need a regular hooked bridle end spring, or you could use 5616 which is slightly thicker at 0.18mm.
I would still check the barrel depth to make sure you can't fit a higher spring. If a 2.0 will comfortably fit then you could go for GR5853
Stuart you are a star, very niceley explained and easily understandable so much so that I will use your method for future springs that I need for ancient pocket watches.
One final question, I will have I will have a look myself across the net, but would you know the correct size spring for a 16 size waltham traveller?
Stuart many thanks my friend, your knowledge is far greater than mine,I shall have a good look this evening when I finish at the coalface, and yes it is a normal hook bridle, no fancy t bars etc on this old movement. It hasn't even got a case, I just wanted to get this old movement running again, it will probably sit in a box somewhere after this until I can source the correct size case, then knowing me it will sit with your collection.
Stuart just to finalise this thread, I took your advice on mainspring size and it was bang on mate, fits lovely. Now I need to source a jewel for the balance as the top jewel is broken, the search goes on haha
Well, it's not pretty, 1 due to the condition of the jewel holding area prior to work and 2 no  sietz jeweling tool in sight and 3 never done this before.
well whilst working on this old unknown ladies size 6 (34mm plate diameter) fob watch I ascertained it needed a new mainspring, help was given on sizing as I couldn't find an exact match by a very helpful forum member Stuartbaker
new mainspring fitted and then as another post in this thread mentioned I needed a replacement balance cock jewel.
i took a gamble and bought a random mix from red rooster on the bay. As luck would have it there was a few in the mix that looked like they would do the job.
so away I went and took the cock apart and started the job
IMG_7470.MOV
Edited by transporter
Attempting to upload short video
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
