Hi all hope it's ok to post for help with a replica watch I have a Tag Heuer Grand Carrera the has unscrewed and is lost the stem tread is perfect with no damage I should be able buy a replacement but need to know the three size or are they all the same? they come in various crown sizes i/e 5.5,6,7.ect does anyone know which one I need thanks John
Hi Jordano,
This needs more info to answer. It is  replica, ok that's fine. What calibre? Is it an ETA 2892? Esslinger has a few Heuer crowns in the 5.5 and 6.0mm size but these are assigned TAg Heuer calibre numbers. If your watch is running on an ETA 2892 I believe the stem is a tap.9, so you should look for something that has a similar look as that on the original Tag, but you may not find an exact replacement. Pictures also always help....Welcome to the forum!
If it's a replica, who knows what you need? If it's not a screw down crown then you can get a bag of mixed crowns (I just got some from RedroosterUK) and see what fits. If it is a screw down then it will need to fit the stem and the screwed tube. A local watchmaker should easily be able to help.
Cheers Neil
Miyota 6S20. That helps yes. The stem for that is 065-A13, Tap 10 which is .9mm. It is unlikely you will find an exact replacement. I looked up Citizen (Miyota) crowns at Startimesupply.com and found this:
58cdd9d1b58b6_ScreenShot2017-03-18at9_05_20PM.png.8eb9c7a65140197c0fa762433de44d0d.png
Thank you so much I have been on the startime site and filled in temporary membership unfortunately the minimum  value of goods to the UK is $100 do you know of somewhere similar in the U.K?
Cousins, HW Walsh, eBay
Good luck!
Neil
Cousins would be the best bet. I have an account at startime and a few other watch material houses here in U.S.  Try Cousins to see if you find it there.
JC
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
