Hi,
I have an Ice watch where the number 6 has fallen lose and the minute hand is rotating freely when holding the watch at different angles. I've attached three pictures.
Can someone tell me:
1. How to remove the crown ? I can't determine where to release it from.
2. How to reattach the minute hand ?
IceWatch.zip
2. You'll need to remove the seconds hands first. Do you have hand removing levers or a "Presto" tool? To refit, it's preferable to use a hand fitting press, but you can possibly get away with using empty biro-type pen cases with the cartridges removed, as long as the hole size is correct for the job.
For that loose hour marker, I would carefully add a minuscule amount of epoxy into the holes using a needle. Don't use super glue or anything fast-setting.
