How to install Watch-O-Scope with digital filter
szbalogh
Thank you for posting this video.  It is a bit confusing at first because you absolutely fly through all the installation and configuration steps and there is no commentary / subtitles to clue in the audience.  But, taking the time to view the video a couple more times, and I get it.
Why did you chose to install the Virtual Audio Connector (VAC) software?  The Equalizer AOL is perfectly capable of attaching itself to the Windows recording device.  The Peace graphical equaliser is used one-time to set the AOL values so it's not part of the signal processing chain.  I would have a suspicion that the VAC's CPU overhead adds an unstable serial delay to the audio delivery but brings no perceptible value to the signal processing chain.  So, it could have an effect upon the accuracy of the Watch-o-scope software, decreasing the reliability of the audio card's timing and adding uncertainty to the timing machine.
    • I would try the vapour treatment very simple just a simmering pot of the stuff and jewels bluetacked ( not whitetacked this time, you still haven't said if I'm forgiven yet 🙂 ) to the underside of the lid. You're now gonna tell me that stearic acid can be highly explosive above 90° C 🤣
    • I guess it also depends on the precision and quality of the watch. He works on vintage watches mainly and surface treatments on 50 - 60 year old watches probably isn't going to make much difference. I read about nano coatings for car finishes. The article claims that nano coatings can reduced the coefficient of drag by 5%. Is that number significant? I don't know. Maybe if you were trying to break the land speed record. But applying that on a 50 year old clunker isn't going to make it go any faster, accelerate better or save on petrol. 🤣
    • 😅 yep certainly overdid it , i wasn't sure if i had enough heat so i went out and left it cooking. You can see the thick frosting, bit like my cherry buns.
    • 5 hours! You have slow cooked it! It must be really tender by now. @nickelsilver posted about his Greiner machine a while back. It had a heated chamber of stearic acid to epilame jewels and it only took 60 seconds. I've tried stearic acid dissolved in ethanol with a flake of shellac. I'm not really convinced by my test results. I conducted a side by side test by coating a mirror with a stripe of stearic acid and putting several drops of 9010 on the treated surface and untreated surface and observed it for several days. The 9010 spread out about the same for both the treated and untreated surfaces. I spoke with my mentor recently regarding epilame and lubricating pallet jewels. He has stopped doing both because he finds no significant improvements to the end result.
    • Used with the correct fitting staking punch it will remove the roller.
