Mainspring Direction
Pip
I'm baffled. It happens a lot that, but this time there is a reason. I have an old Longines movement that I bought in bits, like the most complicated 3D jigsaw I can imagine, and included in it is a mainspring and the two halves of its barrel (is that the right name?). Now to put it back together I need to wind it, but how do you tell whether a spring should be left or right hand wound?
Allied to that is that I don't have a winder of the right size but it's knowledge I'm after as well as kit.847df2a150cab4e8616f2ed8261ba4d4.jpg
As OH says, work out which way up the arbor fits in the barrel, Then look closely at the hook on the arbor (with a loupe) and you will be able to see which way the spring has to go so that it stays hooked on to the arbor.
Thanks Marc
Sent from my brain using evolution and electricity.
    • The bezel feels slightly loose over the case. There wasn't a gasket but could the crystal be expanded over the lip in the caseback and then the bezel pressed over the crystal?
    • The cleaner smells of ammonia, but it's not too bad; just keep it covered as far as practical.  I use an ultrasonic machine on a kitchen worktop. The rinse does not smell strongly, it's vaguely like paraffin. I did check the safety data sheets before buying it & it's said to be safe in normal use. My dedicated watch cleaning machine is still a work-in-progress; four position linear, based on 1L kilner jars for station spacing, to have a heated dryer in position 4. It uses standard, readily available parts as far as possible to make it easy to reproduce, plus 3D printed bits for the custom parts. (The horizontal drive motor is out at the moment while working on the stepper drive software)
    • I disassembled the hands of my Citizen Pilot Super Titanium Radio Controlled AS2031-57E a couple of times.  The second time because on the first attempt i evidently did not push the hour hand well and in practice it was not well fixed and moved receiving even small bumps. After the second attempt everything seems to be ok.  Except that i have the impression that giving a little more sustained blows on the wrist, the hour hand still has a slight movement, in the order of half a second or less. It is a normal, topical and usual thing about this movement, which, i remind you, is exclusively electronically managed, each hand independently, a clearance in the movement that it has of its nature, or it may depend on the hand is not yet well attached to the pin and should perhaps be replaced because the hole has slightly enlarged?
    • This is something a lot of beginners and amateurs struggle with Nev, being able to remove the staff without distorting the hole of a non steel balance wheel. Having the right tools to do this safely  and effectively is not easy. Even with something useful it takes a lot of practice, i spent two days not so long ago practicing cutting away the balance wheel hub of a staff using a 25mm diamond wheel.  I didnt manage to do it once without catching the underside of the wheel.
    • Then you should have something that prevents the case from moving. I just bought one of these Seiko S-210 but haven't received it yet.
