Could anyone please advise me the best place to track down a replacement mainspring for a Seiko 7009A?
Many thanks
Tim
Seiko does not sell MS, only barrel complete which is 201.024, if you can still find one. However I suspect that in practice the same as in the 7S26 for which there is at least two GR parts that you can use. Alt the end of the day, if truly there is a problem with the MS (often there is not), it can be cheaper and more effective getting a small lot of movements from the well known Ebay seller "thewatchcollector".
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
