Date not changing
chrisdt
Hi everyone
I have recently purchased (for too much money) a Bulova Ambassador 23 jewel automatic which on inspection was running well but like the cars oil leak that you only notice after you have paid your money and driven the car home I now notice the date does not change. I'm not in the position to get my money back so its down to me. I wondered if anyone could advise on the possible fault and what is involved. Not done this before but I presume its hands,dial off then I'm lost....
Thanks Chris
9 minutes ago, chrisdt said:
Its a Bulova 11 ANACD  64 Date N1 1971
Chrisdt,
There are four calendar parts listed in bulova book under 11ANACD that correspond to "Calendar parts"
 they are : 571 = Date indicator guard, 574 = date ind dr whl mtd. 576 = Date indicator, 578= Date jumper spring
I am going to assume that they are exclusive to 11ANACD because of statement under parts table,
May not diagnose problem, but will tell you what parts MAY be involved. Might be just the jumper spring, (don't hold me to that, just guessing!) Hope this helps.
    • “Traditional” was probably a poor choice of words. What I was trying to say was that I perceived Waggy's proposal as more modern than the now generally accepted one. Water and sugar? Do you have a source on that or is it just a guess? Is the inside of the crown stainless? Water and metal don't sound like a very good combination otherwise.
    • Hello and welcome to the bottomless rabbit hole! 😉
    • Do you use an ultrasonic cleaner or a watch cleaning machine? I've been considering trying out the L&R liquids you mention in my "ancient" Elma watch cleaning machine. However, I worry that these liquids are too toxic and smell too much without adequate ventilation. Where I live it is normally too cold to work with this outdoors, but a few months a year it could work. At some point, I tried Elma's Suprol Pro and almost passed out from the fumes. It comes with a "narcotic effect" warning. How bad are the L&R fluids in this respect?
    • I've removed the movement and left it on a windowsill. I'm in north east England, so not very sunny today 😥 however I'll give it a few days and then try a new battery. The document you sent claims the movement is the same as the C700 with regards to parts and assembly. I've managed to find an exploded view of a C700 and some troubleshooting instructions. So if a new battery doesn't work in a few days I'll strip the watch and test the electronic circuit unit. No doubt it will require cleaning and oiling anyway. Thanks again for your help @watchweasol
    • Hello and welcome to the forum,     Enjoy
