Low amplitude in vertical position
Hello!
I cleaned a wostok 2209 and I have the following problem: in vertical position (CD) the amplitude decreases from 280 to 190 and it looses (-60s).Dial up it has about 280 deg and it is in +-10s. I tinkered a bit with the HS and it is as flat and centered as I can. It is a Breguet HS.
Any ideas?
Thank you!
Bogdan
The amplitude always decreases in vertical positions compared to Dial up and down. however 90 degrees of loss is excessive.  The amplitude reduction may account for the rate reduction.
The first question is is the poor amplitude isolated to a single vertical position or is it in all?
if in all and you have sure that the balance and hairspring is centred and free in all positions then the most likely cause is excessive friction between the pivots and sidewalks of the jewels either in the balance or train, as this contact is reduced dial up dial down. Need to make sure that all the jewels and pivots are all scrupulously clean. Start with the balance and work your way back.
So the other vertical positions are OK as regards amplitude.
i would take another look at the balance itself. You need to use a high magnification and look closely at the balance and hairspring in the CD position to check that all is ok. it may still be a dirty Jewel with the dirt on the dependant side in the CD position but it is less likely.
Also look closely at the train in the CD position to check for any cause of increased friction.
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
