Where to get a mainspring
Similar Content
The original water proofing for the crystal will not have been that great, so unlikely much will have changed there. I wear a lot of 70 -80 year old watches, and I'm always conscious of the weather ....will it rain....is my sleeve over my watch. So as lot as the fit feels secure and its not falling out... then 👍 -
I love these. I just got my first, a 5M42 0E39 (picked up on eBay) with the grey dial. I was keen to get the original band but alas, it came with an all stainless aftermarket. Where can I get an original band? I do hear about the rubber parts are usually pretty deteriorated. If you get an original can you re-use the metal bits and add them to a new rubber strap?
Given more time and more practice it'll become easier once you get the feel for it.
Dimensions stated were accurate, and exactly matched that of the old crystal. Regretfully i didn't measure the final dimensions of the new crystal after i had removed material as was sanding and then testing against the case until it went in.
