Glycene assembly
Everyone,
im assembling the Glycene and I have a slight issue? The train seems to have a pivot sticking through the dial side stopping the hour wheel. I think I have them in correctly? Up for suggestions I'm pretty sure the sun seconds is correct but I don't know what I'm doing wrong ?
Advice, thoughts?
Thank you, Gary
6 hours ago, Cad101 said:
Does it have a sub second dial your third and fourth wheel may need swapping around did you take pics while disassembling.
I didn't take photos prior of the train wheel. I thought (first mistake) this isn't complicated and should go back in easily. Little did I know. I will take another photo tonight when I get home.
Strange. Can you take the wheels out and, line them up and post a picture. Have you taken the keyless work off and removed the minute to see what is under it. Is the jewel hole good and not cracked causing the wheel pivot to drop through.
    • The bezel feels slightly loose over the case. There wasn't a gasket but could the crystal be expanded over the lip in the caseback and then the bezel pressed over the crystal?  Actually this sounds like a possibility. This is a great forum. https://www.watchrepairtalk.com/topic/20587-old-orient-case/?do=findComment&comment=173918
    • The cleaner smells of ammonia, but it's not too bad; just keep it covered as far as practical.  I use an ultrasonic machine on a kitchen worktop. The rinse does not smell strongly, it's vaguely like paraffin. I did check the safety data sheets before buying it & it's said to be safe in normal use. My dedicated watch cleaning machine is still a work-in-progress; four position linear, based on 1L kilner jars for station spacing, to have a heated dryer in position 4. It uses standard, readily available parts as far as possible to make it easy to reproduce, plus 3D printed bits for the custom parts. (The horizontal drive motor is out at the moment while working on the stepper drive software)
    • I disassembled the hands of my Citizen Pilot Super Titanium Radio Controlled AS2031-57E a couple of times.  The second time because on the first attempt i evidently did not push the hour hand well and in practice it was not well fixed and moved receiving even small bumps. After the second attempt everything seems to be ok.  Except that i have the impression that giving a little more sustained blows on the wrist, the hour hand still has a slight movement, in the order of half a second or less. It is a normal, topical and usual thing about this movement, which, i remind you, is exclusively electronically managed, each hand independently, a clearance in the movement that it has of its nature, or it may depend on the hand is not yet well attached to the pin and should perhaps be replaced because the hole has slightly enlarged?
    • This is something a lot of beginners and amateurs struggle with Nev, being able to remove the staff without distorting the hole of a non steel balance wheel. Having the right tools to do this safely  and effectively is not easy. Even with something useful it takes a lot of practice, i spent two days not so long ago practicing cutting away the balance wheel hub of a staff using a 25mm diamond wheel.  I didnt manage to do it once without catching the underside of the wheel.
    • Then you should have something that prevents the case from moving. I just bought one of these Seiko S-210 but haven't received it yet.
