Hi, I'm trying to locate an ISA J320 movement in the UK, with a calendar at 6 o clock. Cousins sells the movement, but only with a calendar at 3 o clock. Is there an equivalent, or could anyone suggest where I could get this movement?
All help greatly appreciated!
keith
Welcome!
Are you looking for the whole movement or just a part ?
The movement with the date at 6 and the date at 3 is the same, just the print on the date wheel is different no ?
Thank you for the reply. I am looking for the whole movement and in answer to your question, does it mean that although the calendar on my watch is at 6, I can still order a movement with a calendar at 3?
as you've probably guessed I am a beginner, but I have replaced a few movements before
thanks again for any help, keith
Apparently the j320 is the same as the 330. I searched for the ISA-330 and Time Connection Inc has it listed in their catalogue, with the date at 6 (iSA-330.103-D6, page 39)
Disclaimer : I'm not related to anyone at Time Connection Inc and have no idea who they are. I just found them when through a google search for said movement.
You can swap the ring with the 6 oclok oriented numerals with the one the new movement brings. This way the new movement will have the correct 6 oclock display.
