Cool! You're either going to have a lot of fun, or (like me) you're going to get really aggravated when you find out that the serviced watches you were so proud of aren't running as well as you thought they were :huh:
I think you'll probably have fun :biggrin:
Very nice toys! How is your progress so far with them? I got the same equipment (timegraph 1900 actually but very, very much the same). The demag tool requires some practice but it works fine. When I gave some MRI treatment to my watches in the timegraph most of my Seikos and some ETA were really off. I'm still getting there with them...nevertheless, the brand new one was behaving perfectly! Here is one ready for servicing:
Cheers,
Bob
Mostly off by a couple of mins a day as I expected except a seiko sportsmatic which was .1ms and the Roamer popular which I'd serviced the night before but not cased up that was .1 too all the rest are way out. So I'm having fun regulating about 30 watches I'm getting used to the demag its pretty much the same as my old one that was my grandads and was a antique and was quite scary to use and has probably done me irreversible  damage :D
Mick
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
