I have just finished overhauling a Goliath pocket watch . I dont have a crystal for it and didn't expect it to be difficult to get until I started looking that is. Problem is it is 62mm dia it is flat and quite thin probably 1.2 to 1.5mm . Can't find one anywhere . Anyone have any ideas .
A Goliath pocket watch glass should be thick because it is classed as an open face. Getting one of the correct size is about as rear as rocking horse ****
30 minutes ago, Blacklab said:
This any good: ebay item no. 371419840347 one or two others on there as well.
i tried this number but it says 0 listings.
Should it be flat . I thought it would be thin as there isn't much of a recess to install it .It is open face though . I have hundreds of crystals but unfortunately the biggest I have  61 mm
I serviced & repaired hands on  Goliath last year. I remember searching the web (as you do) and did find a Goliath Crystal on the Ebay so they do appear now and again.
found it thanks. Bought a couple . May not be correct but better than nothing until the correct one turns up.
Edited by Ducati2242
