Hello All;
I need to get a longer (ø10=1mm) winding stem for a 23.3mm (10.3'''), 9-jewels, Swiss made, THOR.RUSSELL & SON movement, but the movement hasn't got any caliber identification. All what's stamped in the movement is: Premier, 9-jewels, Swiss Made and Thor.Russell & Son on the ratchet-wheel. The signed dial is 26.5mm.
Anybody recognize this movement and knows under which identification it goes?
Thanks on beforehand ;)
Yes!!! A Thors, Russell & Sons 9 jewels Premier! Roland! where did you get that?!  errr, I have no idea what movement is it and have never seen one before!!! but I can tell you one thing: don't drop it, there is no antishock protection on that one!
Did you try ranfft? My computer is stuck downloading some youtube things so I won't be able to search right now...I will though, I'm as interested as you are!
Cheers,
Bob
Hi Bob......yes I know, it's not a dropper, and therefor you can't loose any cap-stones.....more suited for me :biggrin:
I got it in a lot of 4 from eBay, Three of them were AS984 and this one......
Wondering what you are downloading.......not going to tell me more "watch-stuff" !? :D
Edited by Endeavor
3 thoughts...
1. Have you considered a stem extender?
2. Have you removed the dial to see if there are any markings under there?
3. Looks from here that you might be needing to re-bush the centre wheel pivot
S
Hello StuartBaker104;
Thank you very much for your thoughts ;)
1. Yes, I considered a stem extension, but with the case I have (not the original), which has a kind of tube, there is no room left for the crown any longer, or to be flush with the case......bit hard to explain, but yes I thought about it and I tried with a 0.9mm extension (the maximum size I have) what could be done......but it doesn't seem that it is going to work.
2. Yes, I serviced the movement and no markings to be found under the dial, neither under any of the bridges nor on the main-plate.
3. Excellent spotted ! But, as a beginner, I haven't got the tools and the movement still runs fine........at the moment not many option.....
Thanks again and regards: Roland.
