I have a 168.010 Cal 564 wherein the rotor is catching the case back (can hear it and see the marking on the inside of the case back). I have not set out to do anything with it just yet (still getting my watch repair tool-set together :) ) - but was wondering about what parts I need and where to source them before too much longer noting the Swatch embargo on parts distribution - can anyone advise.
My suggestion, if this rotor accepts a new bearing, is to get a new one and swap it...or get the whole rotor assembly -- rotor and bearing. For the first option, you will probably need a staking set though.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
