Pressing Of Pushers.
rogart63
Hi Roger,
The alternatives from them are about the same...I don't know if you require a special tool but the complete set of pusher tools from Horotec is about that price...sorry about the bad news...maybe some other member knows better?
This is what I use:
msa03.621.jpg  and this: msa03.656.jpg
And there is this option too, but I don't have them:
In order of from top to right to bottom: US$290, US$140 and US$58 each or US$174 since your can buy separate or complete set (only for screwing pushers...I hope the word "up" was not omitted  in the "brochure"  :) ).
The second picture is a set I find kind of flimsy...I broke some of the tips and had to replace them...doesn't come with instructions so it may have been me or simply it is not too good. I've also found it of little use and sometimes a different tool may do the job better....in combination with a hammer too, out of frustration on those old, rusty cases I work on deceiving myself thinking it is fun until...well, I don't want to get started! Amazing what people do to watches! :)
Cheers,
Bob
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
