Chaps by any chance has anyone got a scraper Seiko 7t32. I got distracted when assembling and the setting wheel for the alarm side flew away from my tweezer. After looking in every crevasse known to man it has just gone. I have looked on the bay but too pricey for one tiny part.
Is it part-no. 0281 582?
I have a scrap 7T62 and it has a 0281 580 but no 582.
Good luck
Pauli
Thanks Pauli, Yes that is the same part number i.e. the part I require. If you are willing to sell me the part I will pay you for it via your paypal account or however you wish to be payed.
If so I will PM you with my home address
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
