I'm working on two Waltham 1883 size 18s pocket watches and can't seem to find the problem with either one; which is they wind but do not run.  The balance and staff appear to be okay.  Since I'm a newbie I thought someone might know a common problem(s) with these vintage watches.  How do I check the mainspring because I hear that might be a cause.
Thanks,
Timezone
If the crown ( Winder ) keeps going round and does not come to a stop then there is either no mainspring in the barrel or it has snapped.
I would start by dismantling the winding wheels and then then remove the plate, get the mainspring barrel out, check inside to see what is going on with the spring.
Quite a simple procedure but if you search online for " fitting a pocket watch mainspring " you will find several videos. There may even be one here.
Let us know how you get on.
Mike
Hi Mike:
Thanks for the help.  I'll check out the mainspring as you instructed.  I have a lot to learn yet as you can see.  I'll let you know how I make out.
Thanks so much!
Rich   (Timezone)
Yup - sounds like a broken mainspring. The other problem that occurs with winding is when the click is bust - winds and then winds down immediately - but yours sounds like a snapped mainspring.
Mod:
Thanks for your reply.  The consensus seems to be the mainspring. The clicks are both good.  I'll investigate and let you guys know the outcome.
Cheers,
Rich
Timezone
Thanks,
Timezone
To Mike & WillFly:
Follow up on the above, the mainspring was the problem in both cases.  Thanks so much for your help and info.
Gratefully,
Timezone
(Rich)
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
    • I had one success (and one failure) dissolving a broken stem out of a crown with Alum. The successes was a stainless steel crown and a milder steel stem. A Tag Heuer 2000 Automatic - here with the solution at around 60ºC I could see small bubbles coming up from the stump of the stem and it took maybe 6 hours to disolve I tried to repeat this with another watch and it did nothing.....  This was A Bulova Ambassador with what again looked like a stainless steel crown.
    • That good to know in one way.
