Hi guys,
I'm trying to get C320 and other C type movements as the title says. Also if there is any way to fix them, service sheets or anything I'd appreciate the information.
Thank you in advance!
Cheers,
Bob
Now that's a good question. I was about to give up but finally saw that S.T.Supply had several c models. I did not see the c320 but a c330 was there. I think I have ordered from them before but I can't remember for sure. I did see a c320 on ebay in a complete watch in Canada for about $70.00.
Charles K
Thanks Charles, I'll visit the place as soon as I get home! I got a couple of projects and need different C movements for them. Much appreciated.
Cheers,
Bob
