Anyone help me please.
There's something wrong with Wenger 096.0659. When I adjust the time, the hands interfere each other, even touching with its index. I don't know what is the cause but anyway I'm gonna replace the hands first and then mount them again.
GUCCI 1500L, there's a tiny dust inside of the glass.
But I can't find the setting levers. Where to push? Thank you in advance.
Wenger
http://imgur.com/P9WFQ0H
GUCCI
http://watch-tool.net/replacing-battery/brand/gucci/gucci1500l9.html
Thanks for replying. I think I found an arrow with GUCCI movement. still not sure with WENGER.
I'm gonna open the case and check again.
By the way I've heard some of them need to loosen a screw to replace the stem.(I've never seen yet. basically seen in high quality movement?)
How do you locate it? Maybe it basically line on stem? I'm afraid of touching a screw that must not be touched.
That screw you are talking about is on the side and front, -- in the ETA movement (Wenger) -- next to the stem...you can't see the stem but you can trace an imaginary line from the crown to the back of the movement. If you look at the watch from the crown, the screw is on the left and very close to the imaginary line. Only do 1/2 a turn at a time...the stem should come out at about 1 and a 1/2 turn of the screw.
