Timex Merlin Crown will not Stay on Stem
Thank you @RichardHarris123, @AndyGSi for your ideas. You’re right, sorry for confusion That’s a good point, I forgot mention that the internal hole has three different diameters: 27.5, 25.7 (middle ridge that I’m trying to cut) and 26.1 It doesn’t go through the hole because of 25.7. I think I can align and fix with clamps once the ridge is removed 25.7
From your annotated image, I was able to locate it, but I hadn't been able to ascertain the bend. My unsophisticated eye wasn't looking for a slight twist, which I think I see now. I'll go back and read the referenced posts as well, since they will likely help me understand in greater detail. Maybe I'm making things better?
I would not take the spring off, but this is because I am lazy. But may be it will be easier for You to take it off. It is important to be able to locate the bent place. It is well seen now, but when the spring gets better, locating the place may get harder. So, it is 7th coil from the beginning and direction is about 80 degr against the stud (there is picture so no need to remember) -
@AndyGSi, I thought about running it around the case, but the same diameter of the inside of the case, would be better . -
I appreciate your concern on my behalf! However my relationship with local charity shops is informal & based on trust. I'm not obliged to address any watch or clock that they consider needs attention. What I get out of it is a series of opportunities to learn & practice - assisted by WRT colleagues, my books & YouTube videos - & the satisfaction of the occasional 'notable' (to me) success & of being of some use to good causes.
