Temont Pocket Watch
Yes, being lathe deprived is a problem that I have, so obviously interested in solutions that don't require one. The Balance Staff removers are interesting. I wasn't sure if you could get them in a size to suit a typical wristwatch movement, I thought they were more suited for pocket watch balances. I was surprised to see a staff just pushed out with a Horia tool but I guess if you get a very close fitting stump it would potentially do the same amount of damage as a remover (the only difference being that the remover seems to clamp down the cross arms of the balance immediately surrounding the staff). I did read somewhere that Rolex (who apparently recommend this) balance wheels are harder than others. This is maybe one to try on already scrap balance.
Just checking terminology here. When a pivot is described as having a certain height is that measured from pivot tip to pivot tip or from the face of the wheel to the tip of the extended pivot? I have a bit of a strange one that measures closer from tip to tip but not from the wheel face to tip (I get 3.1mm from face to tip and about 3.6mm tip to tip when badly measured with my Vernier calipers)
This is the best option - if you have a lathe. For those of us without, I use a Balance Staff Remover as shown in your pic. Using this, I have not seen any damage to a balance. Rolex recommend just pushing it out as their balance arms are quite hard. But, as @Klassiker suggests, do a search of the forum and you will find plenty of discussion.
This has been discussed in great detail several times already. All of the methods you mention carry some level of risk. If you search for @praezis posts on the subject, you can find convincing arguments why cutting off the hub (not the rivet) is the safest method.
