Clipped Bezel Insert?
OK, I have no idea what it's called but what I do know is a none clipped bezel insert will not fit!
So the backstory-
I aquired a Bulova Marine Star 200m quartz watch for cheap- 5 USD and a bottle of homebrewed beer (9% Imperial IPA with all Citra hops that I called Citra-**BLEEP** Down). When I saw it it was crusted up with a broken stem and the seconds hand fell off.  It is now running and I would really like to get a new bezel insert but the bezel has notches at 1,3,5,7,9 and 11 preventing a non "notched" insert from being glued.  I tried my best Google-FU but have come up empty handed except for the following:
http://wornandwound.com/2015/09/02/orient-mako-usa-review/
The Orient Mako has the same notches!
Any help for info on finding a new bezel for this watch.
Thanks,
Dan
Good to here from you Dan. It looks like you've been wearing that one after a good few of your special reserves! :D
I'm sure some of the specialists in Bulova will help you out here. The watch has a lot of potential!
Welcome back, stranger!  :D
That's a beautiful Bulova. I hope you find the part you are looking for. I thought the Orient Mako will make do but, is it notched? I don't remember...alternatively, is it possible to make the notches on a regular one? In any case, I agree with Geo about the Bulova experts on the site.
Good to hear from you again, Dan!
Cheers,
Bob
very nice watch. i've seen a few on craigslist around here. been eying them up.
anyway, would it be possible to use a "conventional" insert - one that has the correct dimensions inside and out - and lay the existing one over it and mark out where the notches are and then grind it out with a dremel?
it might be worth the effort. you could practice on a scrap one to see how difficult it is.
now that i clicked the link, i realize that i have two makos and never noticed the notches.
Edited by ramrod
    • The entry and exit stones have different impulse face angles  murks.
    • Depending on how much of the screw is left, you may be able to screw it further in and it may fall out of the hole that the dial foot sat in. To do this I rough up the tip of the good screw and screw it in, often the rough surface of the good screw and the rough surface on the broken screw get enough of a bite to transmit the torque into the broken section and force it out the other side. Like I said the size of the broken screw needs to be in your favor, but you never know you may get lucky.... or if you get it moving you may be able to then back it out with a screwdriver taking a bite on the rough surface. worth a try
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
