Hi, guys
Are there any Timex gurus out there? I'm looking for a winging stem for a Timex Indiglow WR30 and as this watch lacks any reference numbers, I'm lost at sea. The only visible number I can see is on the case back, which is 05. I thought I might be able to put a stem extender on it but then realized it's not going to work as the stem is broken off flush at the crown so if you put the two broken bits together it's obvious there's not going to be enough real estate for the end of the extender.
It would be nice to get the correct part, but if not, then plan "B" would be to use a generic crown that doesn't have the extended tube with the seal on it, It's not ideal but that may work 🤔  From the picture if anybody can identify the part number for the stem I would be grateful.
Okay, my mistake I did eventually see some numbers on the movement but they meant nothing to me, and when I searched any of the numbers I came up with nothing most probably because I don't know the movement manufacturer. Anyway, in no particular order, the numbers on the movement are B43, 15 on its own, and 11 with an M above it
Edited by Zedster
