Hello. 1950’s Leazer watch with a stuck dial. Appears to have had water ingress, movement looks very good, but the screw holes for the dial  have rust in them and I can’t see to get a screwdriver to work in them. Dial doesn’t seem to want to move at all and is solid against the movement. Not sure if there is glue or rust under dial. My first thought is to put something in the dial screw holes to remove rust. I don’t have evaporustwhich is hard to find in Canada. WD40? Vinegar? I’m afraid of hurting the rest of the movement. Any suggestions? I’ve been working on watches for about 6 months now on weekends, first time I’ve run into a challenge like this. Thanks!
personally i would go for a drop of WD on top of the screw heads and wait for it to soak through to the threads.... you might be able to get some to run down the locking side of dial feet, give the fluid time to soak in, a few days. dont try an ultrasonic , good chance it will strip the face completely and leave worse than you already have.
Done. It doesn’t even feel like there is any thing left of whatever screws were in there. Hopefully if that’s the case the WD40 will at least let the feet on the dial go. I’ve been mainly fixing and restoring pocket watches up to now and building wrist watches from new parts so this is my first foray into a vintage wristwatch movement.  Looks like I didn’t pick an easy one, LOL.
15 minutes ago, AndyGSi said:
It looks to me like the screws are long gone as I'd expect to see the slot level with the edge.
As @Neverenoughwatches said I'd put a drop of WD40 in the holes and leave it to soak for a bit.
Do you intend on reusing the dial?
My main intent for this was to restore as if it was a more valuable watch than it is. I would like to try to keep the dial and maybe just save the watch as a trophy of my first vintage wristwatch rebuild. I might consider replacing it if the movement works well. The original case and strap are in very good condition, just dirty. My main goal here is really to practice rebuilding a swiss movement.There was also a beautiful set of gold hands with it, similar to the old Tudor ones.
Edited by capoman
Additional info.
Not sure what you mean by 'restore as if it was a more valuable watch than it is' but what movement is it?
I just mean to do the best job I can with it including cleaning the dial carefully. I didn’t pay much for this, but I still intend to try to restore using as many original parts as possible. It’s an AS 1187.
I get that fella , you want make the best job of your first watch repair. What you do now will be 10 times as less  effective compared to what you can do in a year if you practice regularly and develop the skill and knowledge that follows. Re the dial, you won't make much if any improvement as a beginner but surprisingly enough you could make it a whole lot worse if you try to improve it 😅. So if you want your trophy first watch fix....then mostly leave it be . I think we need more info on the condition of those dial feet screws, as it is we can see the tops of the dial feet and you've shown us some holes where the screws go, but without using my superpowers of night or xray vision....which can only work if I'm actually with you in person looking at your watch with you, then some light in there might give us a clue as to whats going on.
Maybe John will come along with his crystal ball, give it a polish and fire it up John.  Maybe...just maybe...I'm in a funny old mood today. I guess I'll just apologise now in case my behaviour hits an all time low today. Seriously we need to see a screw.
head...oh my
Shoot me now.
head...oh my
Shoot me now.
Thanks for your words. There were two dial feet, not 3 I expected and they are fine. I think there was only one screw with anything left, and nothing there to grip on. The WD-40 did the trick though to loosen things up enough to get the dial off, and it seems to be in decent shape on the underside. The movement came apart without issue after that and seems in good shape. I won’t be getting back to it until next weekend, took lots of pics along the way. I guess the question going forward is what to do to remount the dial when complete? Two dial feet are fine, but not sure the holes are very useful. I guess I’ll see after I give the plate a good cleaning. I have a screw collection I might find some in, but I don’t have any taps that small. I know it’s not kosher, but maybe a couple drops of hot glue would be sufficient, LOL.
If the threads are shot you can re-drill them for a bigger screw size, and the holes to accommodate a larger head or reduce the head diameter if need be. The screw should cut its own thread in the brass plate.
See, there is simple way to take the dial off without damaging it's legs. Disassemble the rear side of movement in order to get to the holes where dial legs go in. Then You must fix the movement as to be able to press the legs trough the holes and in the same time the dial to be free to go down. Press the legs little by little first one then the other, again the first one and so on until the dial is free. In the end You will be able to etch the screws in alum or sulfuric acid
As per my previous post, the dial is off now. The WD-40 did the trick. Just a matter of figuring out how to put it back in if the holes are pooched. Weird that the rest of the movement is just fine, and didn’t have the same corrosion issues as the dial screws.
Sorry, I missed it. But, You already will know what to do in similar situations, where the screws are damaged and will not want to untighten.
Now, if the threads are damaged, just use slightly bigger screw. Put some oil and screw it forward-reverse carefully until new thread is formed to the end.
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
