Landed a very clean looking 6105a movement today, though there's a plastic part in there that's sticking out like a sore thumb - see pic:Screenshot_20241001-2054402.thumb.png.9acc1fb1acf2f2ab4b05c527a2b3a390.png
Has that had a plastic donor date driving wheel holder fitted from another movement? Is it an easy switch out? Anything I should note before attempting to change if I can find the original part?
While I'm here any idea what other models date wheels will fit- 6109 perhaps? 6106 I'm pretty sure is the same? Annoyingly I think I have a 3oclock date wheel here and need a 4...
So the 6105A is a modified 6106A and the part fitted isn't correct.
Edit
Should have added.
What 6105 is it that has a Date @ 4?
Edited by AndyGSi
Edit
Should have added.
Sorry, what I meant is that looking at the position of the teeth on the date wheel, it seems to have a date ring fitted that lines up with a crown at 3 (as opposed to 4 where it should be for these).
Seems someone has probably switched some parts with a donor movement at some point.
I actually have a 6106 here with 4 o'clock date but while I feel I could probably manage a date wheel swap I'm not sure how much work is needed to change that date driver wheel holder (assuming that's what it is)? I'm a real novice when it comes to movement work.
The movement itself looks good and seems to be running ok, though quite probably fast. Hmmm...
4 hours ago, AndyGSi said:
So the Date Ring looks OK to me.
Even though the Crown is at 4 the Date Window is still at 3 on both the 6105 & 6106 (Day & Date).
I thought the same until I mounted a dial and looked at the position of the teeth compared to a photo of the movement.
Here's how it looks - I assume that's a 6106 3 o'clock ring. While they both have 3 o clock windows the calendars rings are different - it's why the newer Seiko's all have 3.8 or 4.1 crowns I think. IMG_20241001_193506.thumb.jpg.a68da17ac5bd6cbe103b67d7bda517da.jpg...
24 minutes ago, AndyGSi said:
I've never seen anything but a 3 o'clock window so expect it's something to do with the ring being out of position.
Your right about the window, but the position of the teeth on the date ring is different depending on crown position... It's slight different depending on whether crown position is at three or four. Hopefully you can pick that out in the following pics (it's close but different !)
Screenshot_20241002-121302.png.51b70bdf6230310feb5f421c070e05dd.pngScreenshot_20241002-121124.thumb.png.87de99fea17ba85210dfbf180553f9cb.png
…yes I encountered this. Bon chance trying to source the four o’clock ring. It took me three fails before I finally took a chance on a donor…
2 minutes ago, AndyGSi said:
Yes I see now and comparing it to this one for sale it looks like someone has also swapped the date dial
…how I was tripped up. EBay-ers posting the stock photo or parts list assuming the rings are the same. A nice email to Speedtimerkollection got the right part sorted for me…
The good news is I sort of have one - I hadn't planned on using my 6106 as a donor but since I've already stolen the crystal from it I guess there's a chance...
It's also whether I have the nerve to work on it... Like I said, novice on movement repairs but I have managed a date disc change before. Date driver wheel holder I'm not so sure about...
Some kind of equilibrium.
Did the date wheel swap, didn't try the date wheel cover as I got scared... 6105a movement reunited with knackered old 6105-8000 dial in Rdunae case (for now).
Not too happy with the hands and the relume of a horrid relume took two goes. All working as should though...
    • I'm a little confused here before servicing everything was fine and now it's not? Then I'm assuming if you run it without the chronograph modular runs just fine or does it give you problems then? Then as far as tightening goes I've occasionally seen people use a staking set and sometimes it works sometimes it doesn't. You can also disassemble and flip it over that sometimes works. Otherwise try eBay and maybe one will come up. There is a tiny possibility if the Problem is on the gear part and not on the center tube that you could purchase a shorter version and pop it on your longer version that's a speculation on my part that may be that might work but if the tube itself is worn then you're going to have a problem then it's back to eBay and just try to find one in the first place all sorts of things will show up on eBay sooner or later.
    • Why do you need a whole balance assembly (balance complete)? Staffs are readily available and cheap.
    • Hi welcome to the forum. Enjoy. dictionary_ebauches_sa.pdf TZIllustratedGlossary.pdf
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
