A family member has sent me some photos of her late father's pocket watch. She needs to know if it is of significant value for Probate purposesIMG-20240919-WA0002.thumb.jpg.4cc131a36808ea3190d69ed598bfe791.jpg. A jeweler has quoted £250 for a valuation but before shelling out such a sum she would like to know if that's likely to be worthwhile. My input is only that the case marking indicates it's 93.5% silver & that the balance wheel looks like it has a cylinder escapement. The key does fit but she hasn't tried to wind it. Grateful for any comments/advice.
Doesn't look of any significance a fairly standard 5 bar cylinder movement. £250.00 to value it, good god I'm in the wrong job, that's 3-5x what its actually  worth. Would be interesting to date it , hallmarks-  Queen Vicky's head and lion salient indicate English Victorian, find the date letter code and assaying symbol to post up please.
It's a nice little watch, however the sentimental value is near infinitely greater than the monetary value.
Anyone looking at "Buy it now" prices on ebay and other sites would drastically over-value it.
See the sold item below for an example of an actual selling price for a virtually identical watch, earlier this year (£12.99):
https://www.ebay.co.uk/itm/126543496906
I'd pass that on to your relative as the taxable value - she's far better off keeping it & the cost of that is negligible.
It could possibly sell for rather more if two bidders particularly liked the look of it, but there are no guarantees whatsoever. I've put unusual items on ebay many times & some sell for the starting price (if at all), as there is only one person actually interested - as with the watch above, just one bid!
Unless they have particularly rare or unusual movements, most of the value in old pocket watches is in the case rather than the movement - that's why there are vastly more movements than complete watches on such as ebay.
Something I have to tell people when they bring in pocket watches, is that they are usually never monetarily worth more than what a service will be, of course with exceptions. They are mostly repaired and restored because its a family heirloom, or some type of emotional attachment. Heck, I had a lady bring in a pocket watch that said Hong Kong on the dial, had a movement with 1 jewel, and a pot metal case. She was told her great grandfather got it as a gift and its been in the family for generations. I pegged it at probably 1990s. She needed some custom work done on the case and tube to get a new crown in. Spent quite a bit on a pocket watch worth just a few dollars. But it reminds her of family and that's what is important to her.
This is known as a 5 bar movement. made on the Swiss French border. Some of the dials are extremely decorative, yours is quite nice and I don't see any cracks to it. The style of the hands are called spade and very ordinary again some are very decorative. Cylinder escapements can be poor timekeepers as the balance is not compensated and the weather will cause fluctuation in time keeping.  £80 if you are lucky. There are thousands of these about.
Edited by oldhippy
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
