Eyup watch people. Another random question lol,  its struck me while sorting through a load of watch bits as to how different these parts are. In the past I've assumed balance staffs and stems are around the 10 - 15,000 mark but thats just a guess based on ronda and dcn catalogs of the 60s having 5,000 staffs and 3,000 stems listed. What about parts like cannon pinions, hour and minute wheels, winding pinions, sliding pinions, ratchet and crown wheels , intermediate wheels, arbors, escape wheels, pallet forks. Are there just as many different sizes of these and are they identifiable at all ?
As @RichardHarris123 said there are unique parts across most calibres so if you multiply the
calibres by the manufacturers you've got to be looking at 100s of thousands of different parts.
I suppose for people that work on the same movements time and time again then
the parts would be identifiable but for the average watch repairer I'd think not.
Unique parts like setting lever springs can be quite easily identified as can staffs and stems through measuring their dimensions . Shame there is no calibre lists for other measurable parts, i thought motion works parts would be less variable in thier dimensions but thats without considering their tooth shape. Arbors would seem to be a good candidate for a list.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
