New High Res Oiling Video
SSTEEL
Old video, but new high resolution, I asked them recently if they had a better quality video as the old one was pixelated.
Thanks for this, I also viewed Part 2 and that prompted to get my oilers out for a good look.
I'm afraid I have a bit of work to do so off to the garage and a fine stone and some 1200 wet and dry and maybe some Brasso.
At the moment they look like this (stuck to double sided tape so they look a bit strange.
More to follow after I've refined them.
Cheers
Jim
Edited by JimInOz
So after some time in the garage, my cheap Indian oilers (Anchor brand) have had a polish.
I'll give them a go and see if they improve my oiling skills.
Original Oilers
post-1141-0-24026000-1446509904_thumb.jp
Polished Oilers
post-1141-0-95280700-1446509558_thumb.jp
Edited by JimInOz
The top pictures are definitely not a good look Jim!
Have you tried the polished ones yet? I'm interested to here your comments on the difference that the polishing makes.
They came out well, how did you polish them, via hand, or buff?
I started with a fine file, then 400 paper for shaping, fined off with 1200 paper and finished on a small felt wheel on my Dremel.
The tips will still pick up big drops of oil. With practice I found that the "lift" out of the oil pool can regulate the size of the drop, as can wiping on the edge of the cup.
    • The bezel feels slightly loose over the case. There wasn't a gasket but could the crystal be expanded over the lip in the caseback and then the bezel pressed over the crystal?  Actually this sounds like a possibility. This is a great forum. https://www.watchrepairtalk.com/topic/20587-old-orient-case/?do=findComment&comment=173918
    • The cleaner smells of ammonia, but it's not too bad; just keep it covered as far as practical.  I use an ultrasonic machine on a kitchen worktop. The rinse does not smell strongly, it's vaguely like paraffin. I did check the safety data sheets before buying it & it's said to be safe in normal use. My dedicated watch cleaning machine is still a work-in-progress; four position linear, based on 1L kilner jars for station spacing, to have a heated dryer in position 4. It uses standard, readily available parts as far as possible to make it easy to reproduce, plus 3D printed bits for the custom parts. (The horizontal drive motor is out at the moment while working on the stepper drive software)
    • I disassembled the hands of my Citizen Pilot Super Titanium Radio Controlled AS2031-57E a couple of times.  The second time because on the first attempt i evidently did not push the hour hand well and in practice it was not well fixed and moved receiving even small bumps. After the second attempt everything seems to be ok.  Except that i have the impression that giving a little more sustained blows on the wrist, the hour hand still has a slight movement, in the order of half a second or less. It is a normal, topical and usual thing about this movement, which, i remind you, is exclusively electronically managed, each hand independently, a clearance in the movement that it has of its nature, or it may depend on the hand is not yet well attached to the pin and should perhaps be replaced because the hole has slightly enlarged?
    • This is something a lot of beginners and amateurs struggle with Nev, being able to remove the staff without distorting the hole of a non steel balance wheel. Having the right tools to do this safely  and effectively is not easy. Even with something useful it takes a lot of practice, i spent two days not so long ago practicing cutting away the balance wheel hub of a staff using a 25mm diamond wheel.  I didnt manage to do it once without catching the underside of the wheel.
    • Then you should have something that prevents the case from moving. I just bought one of these Seiko S-210 but haven't received it yet.
