Hi!
I hope someone can help me with this issueΒ πŸ™‚
I have recently replaced the battery in a Tissot Goldrun Monocoque watch.
Unfortunately, the gasket for the glass was worn and needs to be replaced, and the glass is cracked and also needs to be replaced.
I've been poking around on CousinsUk to find replacements but can't quite find the right one.
The glass is 0.7mm thick and about 21.5mm in diameter. The diameter of the hole in the case is 22mm.
The reference number for the case is H635 330
Can anyone help me with what to order?
Kind regards, Mattias.
Β
Thanks for the reply @AndyGSi
Yes it’s the plastic ring that sits between the glass and the case.
I’m going to order the parts you are suggesting, they are not so expensive so let’s make a try.
Thanks again!
